NI TestStand
how integrate a CVI code in Test Stand
I'm learning my self to use both Labwindows and Test Stand and i have some problems.
I want to generate 5V from my NI PCI 6509 in order to drive relays so i think to use the C code from Finder Examples in Labwindows(WriteDigChan.prj).
I tried to call this CVI code from Test Stand but I couldn't.I need to insert the WriteDigChan.dll in "Module".I don't find the .dll so i tried to create it but it dosen't work at all.
Is that .dll necessary?
Any suggestion please!
Best Regards,
Message 1 of 10
(3,387 Views)
Yes, that dll is necessary. I don't have CVI on my machine but if I recall correctly there should be full working examples, including dlls, in the Example folder for CVI.
CTA, CLA, MTFBWY
Message 2 of 10
(3,361 Views)
Ok that's understood....but "if i call correctly" that is what i need would tell me please how i CORRECTLY call a cvi from Test Stand.
Message 3 of 10
(3,351 Views)
checkout the example "computer.seq" in <teststand>\Examples\Demo\C\
Regards
Ray Farmer
Message 4 of 10
(3,349 Views)
It always shows me this error 😞
Message 5 of 10
(3,345 Views)
is function a defined as a DLLEXPORT?
Regards
Ray Farmer
Message 6 of 10
(3,341 Views)
No..should i declare my function with DLLSTDCALL!
Message 7 of 10
(3,338 Views)
i mean DLLExport sorry
Message 8 of 10
(3,337 Views)
You need to export the functions that you want visible for other external applications, such as teststand, to use.
Checkout the computer.prj associated with computer.seq example.
Regards
Ray Farmer
Message 9 of 10
(3,329 Views)
OK i'll try,thanks.
Message 10 of 10
(3,327 Views)
