NI TestStand
how can I disply multiple window based on previous window value using C#.NET
hi every one,
                  Please give me solution for above mentioned problem.
how can I  displying window which accepts input from user, validate(bool,string,etc) the same and display the other window based on result. At last update the result in testStand variable.
regards
Raghavendra k
(5,636 Views)
Hi Raghavendra k,
you should try this. Init your view with variables from TestStand. I would use Locals or SequenceFile Globals if there is use in a Subsequnce. All the variabels should be stored in a container for more clarity. When there is a update on your view control the based TestStand variable will be updated, too. So your variables are always on top. To get a access to variables you can use the SequnceContext and the PropertyObject Class.
If you have understood this stuff the setting of the result is a children's gameSmiley Happy
Hope this helps
Greetings from the lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(5,631 Views)
hi,
Thanks for reply. But I could'nt understand your stuff.Please can you explain me with an example.So, can get more clarity on this.
Please help.... I am new to Test Stand
regards
rkk
(5,575 Views)
Hi Raghavendra k,
Try this "stuff". Here is a small example.
I have used VS2005 and TS4.0
Greetings
juergen
--Signature--
(5,570 Views)
Hi ,
Thanks for your reply. While call the .dll mehod , the following error occred:
" The .NET method 'showDialog' could not be accessed".
Please can you let me know solution.
My code looks like.
objDotNetModule.SetAssembly(
DotNetModuleAssemblyLocations.DotNetModule_AssemblyLocation_File, "D:\\CTestStandDialog\\CTestStandDialog\\bin\\Debug\\CTestStandDialog.dll");
objDotNetModule.ClassName =
"DialogMaster";
objDotNetModule.CreateObject = true;
objDotNetModule.MemberName = strMemberName; // here memeber name is "ShowDialog"
objDotNetModule.MemberIndex = 0;
objDotNetModule.MemberType = DotNetModuleMemberTypes.DotNetMember_CallMethod;
bool bReturnValue, bReturnValue1;
Type typeClass =typeof(CTestStandDialog.DialogMaster);
Please correct, if I am wrong.
regards
RKK
(5,557 Views)
Is my example running ?
If yes, is the step "Constructor" running ?
I wonder why
this should be false, if "constrctor" was running
Best is: Post your seq.
Greetings
juergen
--Signature--
(5,553 Views)
it works, u r such a genius
(155 Views)
