No.
You could do something similar thats done in the process model sequence file, SequentialModel.seq. That is to check if its been run from valid sequence or sequence file. The SequentialModel.seq entry points, Test UUTs and Single Pass, do a check to see if they have been run from a client file. They terminate the execution if it hasn't
Regards
Ray Farmer
Regards
Ray Farmer
