NI TestStand
help file not found
In LabVIEW, I can't see the help information about TestStand API. When I right-click a property or a method and select the help for this property/method, the following window is displayed
Indeed, the path is wrong. There should be only on Doc subdirectory in the path. But how can I change this path ? or solve this problem with another mean ?
Thanks in advance
Laurent
(3,416 Views)
Hi Laurent,
I have looked extensively and could not find such an error ever reported. Were you able to solve it?
Re-installing TestStand could be a solution, maybe insuring you are installing the latest patches/updates.
If you can't fix the issue this way please let me know so we can investigate deeper, I would need some other info like your OS version, maybe the pther SW installed.
M-Junior
(3,357 Views)
Hi M-Junior
For the moment, I don't plan to reinstall TestStand or LabVIEW as it is time consuming. When I need help on TestStand API in LabVIEW, I open TestStand and look for help in the TestStand help.
This is not very convenient so if you have other ideas, I'm interesting in
I send you a capture of my configuration of NI softwares. I'm on Windows 10, release 1709
Regards
Laurent
(3,345 Views)
Is your machine a Windows 64-bit machine? If so can you post what is the value of the following registry key - Computer\HKEY_CLASSES_ROOT\WOW6432Node\TypeLib\{03B81820-510E-42C6-93B8-CFA253794662}\1.0\HELPDIR?
If your machine is a 32-bit machine, can you post the value of the following key - Computer\HKEY_CLASSES_ROOT\TypeLib\{03B81820-510E-42C6-93B8-CFA253794662}\1.0\HELPDIR
Regards
Anand Jain
(3,328 Views)
I'm using Windows 10 64 bits. The value of the key you ask is
C:\Program Files (x86)\National Instruments\TestStand 2016\Doc\Help\
Regards
Laurent
(3,326 Views)
