NI TestStand
get number of threads
Hi
I'm trying to build a customize operator interface in c#
Is there away to get the threads number in a sequence dynamically(during runstate) via API
 and if so how?
Assi
Message 1 of 8
(4,305 Views)
You can try Execution.NumThreads
Syntax
Data Type
Long
Purpose
Returns the current number of threads in the execution.
Remarks
Do not access this property when handling a UIMsg_Trace message. TestStand allows non-foreground threads to run and complete while TestStand handles trace events. As a result, getting the number of threads is unreliable during trace event handling.
Regards
Ray Farmer
Message 2 of 8
(4,301 Views)
Is  there a limitation in the number of threads that can be generated by teststand?
br
Message 3 of 8
(4,236 Views)
There is no hardcoded limit, but the OS and available resources likley have a practical limit.
-Doug
Message 4 of 8
(4,226 Views)
Thanks for the fast reply.
We are trying to runn more than 100 Threads in parallel and run in trouble with that. But we are not shure if it is thread related.
What are your expirences with the practical max numbers of threads?
Message 5 of 8
(4,219 Views)
What sort of problems are you have, can you give examples?
Regards
Ray Farmer
Message 6 of 8
(4,216 Views)
If you have 100 threads, but 90 of them are generally suspended at any given time then it's ok, but if you are really trying to do 100 things in parallel it's very likely you will run into performance problems. The short answer is, it depends on what those threads are doing.
Hope this helps,
-Doug
Message 7 of 8
(4,210 Views)
Thanks, this information helps.
Message 8 of 8
(4,208 Views)
