05-04-2006 02:19 AM
05-04-2006 04:37 AM
You would have to create a utility that reads your xml file then creates the required SequenceFile with steps.
Have a look at the examples in the TestStand\examples\Tools folder. There is a couple of examples.
This use a ini / txt file to define the steps to create. Also it uses a template.seq file to hold the Steps that are to be used in the target sequence file and uses the Clone method, rather that using the type palettes.
Hope this helps
Ray Farmer
05-04-2006 06:14 PM
Hi MadhuSri,
I think the best place for you to start would be to take a look at our sequence builder tool shipping example. Locate this example at <TestStand>\Examples\SequenceBuilderTool. This example acts as a tool for programmatically creating and executing new test sequences. The tool clones prewritten and configured test steps located in a template sequence to create a new test.
This example does however use LabVIEW to gather the steps. It either uses LabVIEW to directly display step names in a listbox or read from an .ini file.
If you have XML code, perhaps look at some of the XML VIs in LabVIEW to manipulate the data.
Hope this helps!
