>>>>>>>ok, I'm getting a different error code: error code 7 instead of a error code 1127 with the error:
Error Code:7 Could not process LabVIEW VIs. Fix any broken VIs before rebuilding. LabVIEW
error: Invoke Node in TestStand - Dist Cmp Settings to Disk Hier.vi->TestStand - Build VI
Distribution.vi->TestStand - Build VI Distribution AX Wrapper.vi->TestStand - Build VI
Distribution AX Wrapper.vi.ProxyCaller
>>>>>>>>And I did a mass compile of the directory mentioned above and I got this error:
#### Starting Mass Compile: Thu, Jul 15, 2004 9:44:04 PM
Directory: "C:\Program Files\National Instruments\TestStand
3.0\Components\NI\Tools\Deployment Utility"
CompileFolder: error 13 at C:\Program Files\National Instruments\TestStand 3.0\Compon
ents\NI\Tools\Deployment Utility\DeploymentUtility.exe
#### Finished Mass Compile: Thu, Jul 15, 2004 9:44:17 PM
