NI TestStand
error -1073807300 causes and fixes
Of four identically stations one commonly throws this error during one of several CVI compiled functions. This indicates a memory problem (windows?) or can this actually be an instrument problem? What are the common causes and fixes for this error?
(3,593 Views)
You may find the following documents useful:
1) http://digital.ni.com/public.nsf/websearch/862567530005F09C8625659A0076B772?OpenDocument
2) http://www.ni.com/support/labview/visa/verr5.htm
3) http://ae.natinst.com/operations/ae/public.nsf/fca7838c4500dc10862567a100753500/5db4ac1cf1e4d65a86256ae200567477?OpenDocument
Some of the documents refer to LabVIEW, but the error code and descriptions outlined in these documents may apply to CVI as well. Let me know how it goes. Hope this helps!
Bob
(3,593 Views)
Hello Ganrim,
You do not mention which kind of operations you are doing when you get this error. I assume you are communicating with an instrument using VISA (or IVI?) since the error seems to be related to VISA. What is the instrument you are talking to? When exactly do you get this error?
Actually, you should try posting this question (providing the answers to my questions, as well as the versions of all the software you are using -VISA, CVI and so on) in one of the Instrument Connectivity Discussion Forums (there is one for Serial Interfaces, one for GPIB, one for VISA and one for Instrument Drivers/IVI). That would be a more suitable p
lace for this question since this error is Not related to TestStand.
You might also check the following knowledgebases that talk about some instances when you might encounter this error:
Knowledgebase 15REIBHL: Message for Error Code -1073807300 Is Not Descriptive Enough
Knowledgebase 2EA9M5PG: Problems Assigning Large Buffer Sizes to My Built-In Serial Ports Using VISA
Carlos L.
(3,593 Views)
