dynamically selecting active report in TS2012
TS2012
I have multiple reports configured (all different displayable reports), and they all generate just fine (they're all on disk where I think they should be)
At the end of execution, I get the default visible displayed report showing, and in the upper-right coner I have the "Active Report" control.
I am looking to find a way to dyanamically set (at the end of the execution -- decision is based on final results of UUT) the order of that list, and possibly remove some reports from the list.
Said a different way --
At the beginning of execution I want to start out with some defaults that generate 6 different reports, and they will be generated in order 1-2-3-4-5-6 and end up on disk.
After testing the UUT (but before the reports are displayed to the user) I need to remove some and reorder the rest, such that 4-2-6-3 are allowed to be selected from the "Active Report" dropdown (with 1,5 removed).  (and #4 is shown by default to the user).  Which ones get removed and how the reorder happens is based on the test results of the UUT.
Could I get a few pointers in this direction?
(4,189 Views)
Have you seen this forum post: https://forums.ni.com/t5/NI-TestStand/Set-Active-Report-Configuration-in-Sequence/m-p/2470748
This papaer has good information too: https://www.ni.com/en/support/documentation/supplemental/08/teststand-report-generation-and-customiz...
                                                       http://www.ni.com/white-paper/14200/en
Applications Engineer
(4,146 Views)
Accepted by warren_scott
I think you can modify the Execution.Reports collection to get what you want.
I configured two reports and then put the following statement in a PostUUTLoop callback to swap the order they appear in the list and it seemed to work correctly.
RunState.Execution.Reports.InsertExisting(RunState.Execution.Reports.Remove(0), -1)
(4,142 Views)
Yes, that seems like a good solution. Thanks for sharing.
(4,124 Views)
Thanks James --
That got me off to the right direction and I've got it working now.
(4,107 Views)
