07-22-2013 02:47 AM
Hello
I need to display the requirements from sequence file properties in the report header.
This header is generated in XML.
And as the requirements are a property of the sequence file, I thought it would be easy. But I don't know how to retrieve the value in the model.
Does anyone know how to do that?
07-22-2013 06:21 AM
It is possible to include the Requirements in the Teststand report. you can SequenceFilePostStep Callback which will take the Requirements.Link[n] array and write it into the ReportText property.
Just put an f(x) statment in der Main Group of the Callback with the following Expression :
Parameters.Step.Result.ReportText += Parameters.Step.TS.Requirements.Links[Locals.i] + "\n"
See the attached seq-file
07-22-2013
06:26 AM
- last edited on
09-20-2026
04:16 PM
by
Content Cleaner
If you want to add custom data to your TestStand report header when using the XML report format, just click on the link below for more detailed information:
How to Modify a TestStand XML Report Header
I hope this helps you.
Houssam
07-23-2013
07:42 AM
- last edited on
09-20-2026
04:16 PM
by
Content Cleaner
Houssam,
Thank you for your answer and thank you for the link "How to Modify a TestStand XML Report Header".
Actually, I'm looking for a solution that modifies the model (and not the sequence) as this configuration will have to be done for each sequence file.
Furthermore the requirement I want to retrieve is a sequence or a sequence file requirement (not a step one) and I want to put it in the header (I think if I create a sequence file post step it will create a new result but not modify the header and as I'm quite new to TestStand and I don't know how to get the last result)
Nais
03-05-2024 10:30 AM - edited 03-05-2024 10:42 AM
I have tried same way. It Worked. Thank you
