NI TestStand
difference between Batch serial number and Batch UUT serial number
Hello
I 'would like to know the difference between Batch serial number and UUT serial number. What is a us a batch serial number? , how two runs ?
since I'm looking on the net I have not found answer congrete.
if you have a link that can help me, I'd appreciate.
thanks
(3,751 Views)
When you have a panel made up of multiple UUTs, sometimes the panel itself is assigned a serial number along with the individual boards before they separated from the panel. If your company does not do this or if you are using separated boards, ignore it.
(3,732 Views)
