09-02-2026 03:27 AM
Hello
When I convert a sequence file from Testand 2014 to Teststand 2019 i see differences in the Goto steps.
As you can see in the picture below the step should jump to "wait front door open" but when i open the teststep the destinaiton is "wait check door closed"
Is this a know issue or do i do something wrong
Solved! Go to Solution.
09-02-2026 05:13 AM
// Irony on
Yes... you are using GOTOs and you are updating from an ancient version to a sligthly less ancient version
// Irony off
This behaviour sounds strange... what you could investigate though: save the File in 2014 in XML and save the imported version in 2019 as well in XML (Edit --> Sequence File Properties)
Use TestStand Diff/ Merge Tool to compare and especially take a look at these Goto Steps
Yes. A **GOTO** should target a **Label** step, and that target should survive step reordering. So if an upgrade appears to retarget a GOTO, that usually points to one of these issues:
| Likely cause | What to check |
| **Broken label reference** | Open the GOTO step and inspect **Destination**. Does it still point to the intended **Label**? |
| **Duplicate or renamed labels** | Check whether migration created multiple labels with similar names or changed descriptions. |
| **Reference-by-index behavior from older content** | Older sequences sometimes behave as if the target was tied to step position after edits/imports/copy-paste. |
| **Cross-step-group logic** | Verify the target is in a valid location. GOTO behavior across **Setup / Main / Cleanup** can be tricky. |
| **Sequence merge/type conflict side effects** | If the file was mass-converted, some internal references may have been rewritten unexpectedly. |
### Best path
1. Compare the **TS 2014** and **TS 2019** versions side by side.
2. For one bad GOTO, note:
- source step name
- expected label
- actual label after upgrade
- whether steps were inserted/deleted before conversion
3. Prefer **unique Label steps** as targets, not ordinary steps.
### Common mistake to avoid
Do **not** trust the label *description* alone; verify the actual selected destination in the GOTO configuration.
If you want, I can help you build a **systematic check list** for migrated sequences, or troubleshoot **one specific sequence** if you share the step layout.
Hope this helps
09-02-2026 05:47 AM
Thanks for you response
I think i solved the problem. The sequence file was first converted from TS2014 to TS2019 and then parts of the sequence where copied to a new sequence file. Then the goto probably lost its reference
so a copy of teststeps that include a Goto will not work. could that be the case ?
09-02-2026 07:37 AM
The part with copying would have been a good hint 😉
Guess this depends on how you define the references. Anyway, I would be careful when copying.
