Online shopping is currently unavailable.
Please contact us for help or try again later.
03-31-2026 07:30 PM
hello all,
i have a Teststand sequence file xxxx.seq, it has multi sub-sequence and lots of different steps. i can't use Edit->Diff Sequence File Against or Teststand File Diff and Merge Utility directly.
Everytime it will disappear when the progress bar around 70% without any notification.
i tried with Teststand 2017/2019/2021, similar issue. i do believe maybe so many items need to be compared and the software crashed in some way.
i just want to ensure the changes not impact other steps, so is there another way to compare .seq file? so i can see where was changed compare with base version?
08-10-2026 03:04 AM
Issue details are not complete. If you just want to compare, you can first convert your .seq file to XML encoding using "TestStand Sequence File Converter" and then compare your old and new seq files using any tool.
