NI TestStand
check if sequence is pass or fail in post uut
hi, i need to check in the post uut of a sequence if it is pass or fail so to do different things depending on the result.
is there any property or variable i can use to check that? thank you
(1,261 Views)
You can use SequenceFailed property. See this: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000wyKCCAY&l=pl-PL
Michał Bieńkowski
CLA, CTA, CPI
  1. Did someone devote their time to help solve your problem? Appreciate it and give kudos.
  2. Problem solved? Accept as a solution so that others can find it faster in the future.
  3. Contribute to the development of TestStand by voting on the TestStand Idea Exchange.
(1,246 Views)
