NI TestStand
char data types in teststand c++ dlls
Hi there.
Apologies if you have already answered a question similar to this, but I couldn't find one that was quite the same.
In my DLL, I want to pass in a string variable, and pass out another string. The actual data transfer is ok, but only after I have manually edited the prototypes, as in the "Specify Module" dialog for a C++ call it always seems to default to "Signed 8-bit Integer" from the "Numeric" category in the parameter details box for a "const char*" (where in fact I want "C String (const)" from the String category). For the output string I want "C String Buffer" from the "String" category but always seem to get "Signed 8-bit Integer" from the "Array of Numbers" category.
Can you tell me what I need to put i
n my IDL file to make it so that I don't have to manually change the prototype?
Peter Dawe
EADS Astrium.
(3,435 Views)
You need to add some custom attributes to your parameters in the IDL. This KnowledgeBase article should answer all your questions:
Title: How Do I Create a Type Library Using Visual C++?
KnowledgeBase ID: 1P68ATSR
(3,435 Views)
