I have created a step type, where the edit substep programatically changes the step name by a labview diagram. It works, but I do not see the changed step name reflected in the sequence editor display right away. I need to right click on the step, properties, click cancel. Any other action works also.
Furthermore, when in the tree view, and adding/editing steps, I saw where the tree step names on the left and the step names on the right pane did not match after programatically changing the step names. I had to right click on "main" at the top level of the tree on the left, and select sequence properties, then cancel. Seems like the gui is not refreshing, and I see no way to "refresh" the gui. Is there a way to programatically do a refresh of the gui as a workaround? BTW, it does not always behave this way, I did see once where the change was reflected right away, just not very often.
