ni.com is currently experiencing issues. Support teams are actively working on the resolution.
NI TestStand
asynchronously release object teststand 2013
I would like to know if it's possible to release a vi which is called from teststand asynchronously.
"Unload all modules" does not work, maybe because I use a reference to send data to teststand.
On internet they say press the "object release" button but I could not find this.
(4,119 Views)
Hi Bart,
This is a bug in TestStand, which has been reported. If you open the vi from Teststand (edit vi option) it will relaese the vi properly after running the sequence.
When the vi is reserved by TestStand, close labview and run the sequence again. The second time, the vi will be released properly.
Bas
(4,091 Views)
