10-25-2011 08:59 AM
Recently we checked the box "Check User Privileges" under Station Options->User Manager.
Now when we try to start the Teststand Sequence editor it opens but with all functionality grayed out so that no action whatsoever can be taken.
If we make an attempt to use File-Login no new box appears but the GUI flickers for a millisecond as if a dialog was open and closed at almost the same time.
If we try to start a sequence file directly from windows explorer it replies with an error message : "Could not open the sequence file(s).... Error code: -18360, User does not have required privilege".
What has happened and does anyone have any good ideas about how to remedy this?
11-03-2011 03:17 PM
Hi GiangV,
You can change the "Check User Privileges" setting back to the default by modifying the TestExec.ini file, located by default at (C:\ProgramData\National Instruments\TestStand 2010\Cfg)
With TestStand closed, change the line CheckUserPrivileges = False to CheckUserPrivileges = True
Also, the login dialog issue can occur if the loginlogout sequence becomes corrupted (this would explain the flickering behavior). To restore this sequence to its default state, you can do the following:
Hope this helps!
11-14-2011 06:33 AM
Hi Ballington!
Yes it does help, thank you so much.
Best Regards,
Giang
06-12-2012 04:36 AM
HI,
I have a problem.I have made this step for that discussion http://forums.ni.com/t5/NI-TestStand/User-Manager-Globals-with-Depolyed-TestStand-System/td-p/106202......Now when I try to start the Teststand Sequence editor it opens but with all functionality grayed out so that no action whatsoever can be taken...Replace the old FrontEndCallbacks.seq without modification in C:\Program Files (x86)\National Instruments\TestStand 4.2.1\Components\Callbacks\FrontEnd and Test Stand ask me the CDistallation...This problem has been solved, but there is a different way of going back once you have the steps in the link? Who can aswer me? Thank you
