NI TestStand
XML REPORT 'DiscardResult' & 'On the Fly Logging' Databse Option
Hi:
I'm using Parameters.DiscardResult at SequenceFilePostResultListEntry callback to filter my XML Report.I wonder why the filtering does not function when 'On the fly Logging' at Database option is True.
I'm using Testand 3.5.
ofer
(3,060 Views)
You would also have to discard the results in the ProcessModelPostResultListEntry as well.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,046 Views)
Thanks Sam,
But how can I change anithing in the process model? Can u give me some link that explain the material?
Ofer
(3,030 Views)
Hi Ofer,
The process model is just another sequence file so you would edit the ProcessModelPostResultList callback just as you did for the SequenceFilePostResultList callback in your sequence file.  The process model associated with your sequence is shown in the bottom right corner when the sequence file is open.  Simply double-click this file name to edit this process model.
Have a great day,
Ecleamus R.
(3,019 Views)
Thanks all for your help
Ofer
(3,004 Views)
