Hi Jake,
A bit more information is required,
What versions are your running,
Any error messages,
Are you running with the RuntimeServer from your GUI, If so do you have the same problem if to configure the use LabVIEW as the server.
Have you tried putting break points on these steps and stepping into the steps to see whats going on.
Regards
Ray Farmer
Regards
Ray Farmer
