Dear Mr. Heer-
I have been performing some tests since I received your question. This should help clarify what you are seeing using the 5112. The NI-Scope driver does not currently support simulation. The 5112 does support measuring waveform types, auto setup, and retrieving the scan mode. However, it appears there are some issues with using the Extensions tab at this time with the 5112. Fortunately, you can still take advantage of the extensions that the 5112 supports by using other operations within the IVI-Scope step type.
To perform the following IVI functionality supported by the 5112 in TestStand, do the following
* To measure a waveform, select "Read" from the main Operation ring control and choose "waveform" from the Waveform Type ring control.
* To perform an auto setup, choose "Auto Setup" from the main Operation ring control.
* To retrieve the scan mode, choose "Get Information" from the main Operation ring control. Select the numeric TestStand property/variable you want to store the value in from the "Sample Mode" ring control.
These issues will be resolved in a future release of NI-Scope. Please let us know if you have any further questions or issues.
Michael
