NI TestStand
Why Teststand modifies the types folder though i haven't done any modification?
I have a custom step type which uses a custom data type. When i open the sequence, Teststand immediately modifies the step type and says (modified) next to the version in the types view. Also it puts a star mark next to my sequence file name. Now i save my file and close it. When i open the file again, Teststand modifies the step type again and puts a star mark mext to my sequence file name.   From other posts, i have found that it has something to do with my custom data type version.
Any more light on this issue would be much appreciated.
(3,092 Views)
Hi Sarasvisu
It seems you have a type confict.
You could use  SequenceFileDiffer.exe to solve it.
or maybe you could slove it with TS editor itself
just goto
1.) Configure->StationOptions->Preferences->"Before Saving Modified Types:" Set to "Prompt to Increment Types"
2.) If using TS4.2 Configure->StationOptions->File->"Allow Automatic..." Set to "Never"
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,088 Views)
Hi Juergen,
Thanks for your reply. I just found out one of my step variables property was set to SHARED. I don't remember why i set this to SHARED. But definitely this is causing the issue. When i reset the flags, now Teststand does not update the types folder. Everything is sweet now. Also Teststand used to take lot of time for processing, so when i click any of my step type, i used to get the hourglass for few seconds. Now it doesn't happen anymore. Never play with SHARED property anymore.
(3,083 Views)
