NI TestStand
Why TS Always Create the Directory tree that I ever used.
As the title,  why TS always create the directory tree that I ever used, it was created when the seq editor opening as below even I have deleted it many times, how can I disable it.
C:.
└─C# MTS_2017_V3
    └─bin
        └─Release
            ├─AdapterSupport
            │  ├─CVI
            │  └─LabVIEW
            └─Components
                └─TypePalettes
(1,950 Views)
Do you run the default NI TestStand installer?
I honestly doubt that and would expect the installer to be a custom UI. If that is the case, you have to ask the vendor of the UI why that folder exists.
Default TS does NOT create that folder.
Norbert
Expert: Geometry
(1,920 Views)
Hi Norbert
Yes, I use default NI TestStand installer, but I custom the UI by myself also,  the directory is just the root directory of my project.
the directory was alway created after I rename or remove it.
Thanks!
(1,917 Views)
