‎03-20-2023 09:18 PM
Hi, Guys:
I have a questions need your help.
The thing is, I saw a question in the NI discussion area about how to create a customized NI Teststand operator interface. Here is the web link :
https://forums.ni.com/t5/NI-TestStand/How-do-you-create-multiple-execution-windows-for-a-cust...
I found a reply as below and said it can refer to another example:
http://sine.ni.com/apps/we/niepd_web_display.display_epd4p_guid=DD175F28D70014DAE034080020E74...
But when I click on this link, it jumps to the Home page of the NI support area, which means that this page no longer exists.
I am currently trying to use create a customer operator interface of NI Teststand through .NET (I don't know how to build Labwindow/CVI project and it report errors always), so I sincerely hope to have this example as a reference. Do you have a backup of this example here? Or can I access it through other links?
Thank you for your help!
‎03-21-2023 08:37 PM
See Working with the TestStand Simple User Interface - C#.NET
This user interface example is located in the following directory:
<TestStand Public>\UserInterfaces\Simple\CSharp\TestExec.sln
‎03-21-2023 09:21 PM
Thank you very much for your reply!
But I think you may have misunderstood my meaning.
I can now implement a customized Teststand user interface, including using ActiveX controls provided by NI, or through a console program that is invoked through command line+parameters. What I hope is that by changing modelsupport2.dll, there is no UUT dialog control (integrated into the main interface). In the link I am looking for, it is said that it has already been implemented in C #, which is why I am looking for this link.
thank you so much again for your help!
‎03-21-2023 10:29 PM
Perhaps these?
Disable or Modify the UUT Serial Number Dialogue Box in TestStand
Customize UUT Information Dialog Box in TestStand
‎03-21-2023 10:37 PM
Yes, this is the information as I need. Thank you very much for your patient help!
