NI TestStand
Who has a valid link available for c # customized modelsupport2.dll of Teststand
Hi, Guys:
      I have a questions need your help.
       The thing is, I saw a question in the NI discussion area about how to create a customized NI Teststand operator interface. Here is the web link :
       https://forums.ni.com/t5/NI-TestStand/How-do-you-create-multiple-execution-windows-for-a-cust...
      I found a reply as below and said it can refer to another example:
       http://sine.ni.com/apps/we/niepd_web_display.display_epd4p_guid=DD175F28D70014DAE034080020E74...
      But when I click on this link, it jumps to the Home page of the NI support area, which means that this page no longer exists.
      I am currently trying to use create a customer operator interface of NI Teststand through .NET (I don't know how to build Labwindow/CVI project and it report errors always), so I sincerely hope to have this example as a reference. Do you have a backup of this example here? Or can I access it through other links?
      Thank you for your help!
(2,669 Views)
See Working with the TestStand Simple User Interface - C#.NET
This user interface example is located in the following directory:
 <TestStand Public>\UserInterfaces\Simple\CSharp\TestExec.sln
https://tmesystems.net/
(2,622 Views)
    Thank you very much for your reply!
    But I think you may have misunderstood my meaning.
    I can now implement a customized Teststand user interface, including using ActiveX controls provided by NI, or through a console program that is invoked through command line+parameters. What I hope is that by changing modelsupport2.dll, there is no UUT dialog control (integrated into the main interface). In the link I am looking for, it is said that it has already been implemented in C #, which is why I am looking for this link.
    thank you so much again for your help!
(2,617 Views)
Accepted by angus2022
Perhaps these?
Disable or Modify the UUT Serial Number Dialogue Box in TestStand
Customize UUT Information Dialog Box in TestStand
(2,609 Views)
Yes, this is the information as I need. Thank you very much for your patient help!
(2,604 Views)
