NI TestStand
Where to get Sequence name for logging into Database?
Hello
I need to create a custom schema for database logging which consists of a table to log Sequence name and its Execution status(Pass|Failed),
this will include the name of sequence along with the sub sequences executed from sequence file.
Please let me know from where i can get a property to access the sequence and sub sequence name.
Regards
Nitin Goel
(4,019 Views)
Hi Nitin,
Go to expression browser in any expression, select Operators/Functions tab. Here select property in the Functions category and select NameOf() function. This function can return name of any property.
e.g. NameOf(Step), NameOf(Sequence),etc..
Kaustubh
(4,011 Views)
Thanks for information i hope this will be helpfull but before that i need to know that how do i add a new Column in the statement "SEQUENCE_SEQCALL" which is also present in the Generic Recorset Schema. I tried to make a new schema and copied "SEQUENCE_SEQCALL" statement and then added a new column "Status" with expression "NameOf( RunState.Sequence)" and saved the changes.
On executing the sequence with database logging enabled i get an error, see attached image for the error.
(4,006 Views)
Hi Nitin,
Don't use RunState.Sequence, instead just write NameOf(Sequence). That error might be for RunState.Sequence.
Kaustubh
(3,995 Views)
Sorry....... Wrong guess. TestStand can automatically convert Sequence to RunState.Sequence
(3,993 Views)
Hi Nitin,
This functionality is already built into a schema provided with the TestStand Sequence Editor.  Navigate to Configure » Database Options in the Sequence Editor, and select the Generic Recordset (NI) under the Schema tab and then select STEP_SEQCALL in the Statements tab.  You will then be able to see that this is already done in STEP_SEQUENCE_NAME column.  You can use the value passed in the Expression field in your custom schema to achieve the same results.  The expression used is Logging.StepResult.TS.SequenceCall.Sequence.
Jessica
Product Support Engineer
(3,846 Views)
