I seriously cannot follow the API for TestStand. I have coded up a LV routine that can add/remove measurements and limits from a multiple numeric limit test- but some of the items completely elude me.
For example, if I leave a single measurement in the list on the MNLT test, I can clone it, update the parameters I know about, and all the results look good.
BUT if I just add a new one (rather than cloning the old one), and set the parameters I think are important, the report will not contain columns for the Units, comp, limits, etc. But I can't seem to find any information on what properties would cause this.
I can't find documentation to tell me what properties and values exist in each of these PropertyObjects, and I can't even seem to pull info about what's available by calling API props/methods at runtime. It's like you have to know what you are looking for ahead of time.
Also (and I asked this in another question), I can't seem to find the correct "NumericFormat" property in order to set the format of the number in the report. I created a step with serveral non-standard formats and tried to use the API to find them at runtime, and I literally cannot find them.
Am I missing something? WHERE IS THE API DOCUMENTATION FOR THESE ITEMS?
