07-06-2020 10:01 AM
Where (folder/file) are the settings stored on computer for things like Report Options, etc.? Is it a .INI file we can view?
Solved! Go to Solution.
07-06-2020 10:57 AM
Most of those settings are stored in the "TSAppData\Cfg" folder, which is located in a directory similar to C:\ProgramData\National Instruments\TestStand 2019 (32-bit)\Cfg. Most specifically on the report options, dive deeper into the ModelPlugins folder to find ResultProcessing.cfg. This is actually an XML file.
07-06-2020 11:08 AM
Thanks crossrulz!
I found this XML file, but doesn't look like it updated the contents based on what I entered in the Report Options UI. The file's modified date/time is also not the same when I updated. It must be getting saved somewhere else.
07-10-2020 10:13 AM - edited 07-10-2020 10:16 AM
By Report Options UI, you are referring to when you go to Configure -> Result Processing? I'm also assuming you are using a default Process Model, because the behavior can change if you are using a custom one.
But by default, all that information is saved to "C:\ProgramData\National Instruments\TestStand ###\Cfg\ModelPlugins\ResultProcessing.cfg"
It updates when you close out of that Result Processing window. And the timestamp will change if you made changes.
If that is not doing it, I would check your Environment. Configure -> Environment. If it's not set to the Global environment, or if you have enabled custom directories, it will save to a different place.
07-18-2020 11:01 AM
@ShockHouse Thanks for the help. That was what I noticed where I pointed my config directory to another location under Configure > Station Options... > Preferences > Configuration Directory.
