NI TestStand
When Does Test Time Get Populated?
Hi everyone, I am using the Sequential Model and my entry point is Test UUTs.  I know I can access the Test Time through Parameters.MainSequenceResults.TS.TotalTime parameter.  In which call back withing the Test UUTs does this Parameter actually get populated?  When is the test actually considered to be done?
Thanks so much!
(4,382 Views)
Hey testdesign,
After doing some tests using Message pop-up Step Types, I was able to answer your questions.
- The MainSequence Callback
- Setting the time begins when entering the setup of the MainSequence.
- The time ends when exiting the cleanup of the MainSequence
You can see this yourself by adding an expression to watch and putting a breakpoint just before the MainSequence Callback.  When the program stops you can Step Into the next part of the code and watch the expression Locals.ResultList[0].TS.TotalTime.
Taylor
(4,341 Views)
That's great info.  Thanks Taylor! Smiley Happy
(4,335 Views)
