02-15-2016 12:38 PM - edited 02-15-2016 12:39 PM
Solved! Go to Solution.
02-15-2016 12:51 PM
@ManasaM wrote:
Hi All, Can any one explain me this error?
And what exactly is "this error". What is the response you get? How are you doing the conversion?
02-16-2016 12:35 AM
Sorry for the improper communication .. image was not attached.
please check this image:
02-16-2016 03:51 AM
The Result.Response variable is a string, that's why you get this error. The Float64() function expects a number.
02-16-2016 04:26 AM
If you want to get the entered "number of iterations" from the Message Popup step, better use the Val() function:
Locals.numberOfIterations = Val(RunState.Sequence.Main["Select number of iterations"].Result.Response)
02-16-2016 04:38 AM - edited 02-16-2016 04:41 AM
Actually i found this function (float64()) in TestStand for loop example.
Where do i get the list of functions available in TestStand?
Best Regards
Manasa M
02-16-2016 04:44 AM - edited 02-16-2016 04:44 AM
You find all available functions in TestStand help.
if you create an expression, click on this symbol for expression browser.
You will see all the functions in a structured way for numeric, string etc. with their help:
