NI TestStand
What is the difference between Deploy TestStand system(3.1) and Run Engine Installation wizard(1.0) in Tools menu
Run Engine Installation wizard(1.0) is a old tool from TestStandVersion before 3.0
Deploy TestStand system is the new tool since Version 3.0, and is the recommended tool if you want to deploy a TestStand System. The Engine Installation wizard is still there for compatibility options, but is much less flexible then the new Deploy TestStand system tool.
(2,979 Views)
