04-04-2018 11:40 PM
Normally production test sequencer has this configuration : STOP_ON_FAIL.
In normal production if a test step fail, test sequencer will stop, skip the remaining test steps and show up failure. This can save test time.
But in some cases (for example to deeply investigate the failure part),we need the sequencer do NOT stop when it fail, until go through all test steps, This is sometimes helpful for failure analysis.
What is the best way to achieve this in TestStand?
Solved! Go to Solution.
04-05-2018 04:45 AM
Do you have the station global "Immediately Goto Cleanup on Sequence Failure" set to achieve this behavior?
If so you can programmatically set it to false so that the program continues after a failed step. (Don't forget to enable it again)
04-05-2018 06:40 AM
Configure----> Station Options------->Execution--->uncheck (Immediately Goto Cleanup on Sequence Failure)
04-05-2018 06:04 PM
Hello Palanivel,
I tried,It work.
Thanks.
Mark Zhou
04-05-2018 06:05 PM
Great!
Thanks.
