NI TestStand
What Lookup String can I use to get the sequence file name and the step name form a DLL?
My sequence makes a DLL call to a function written in CVI. In that CVI function I need to know the name of the sequence call and the name of the particular step that made the call. I know that by using the function TS_PropertyGetValString I can get different parameters. What is the Lookup String that I should use to get the name of the sequence (actualy, the file name) and the name of the step that made the call?
With respect,
Yariv Guy
Enertec
yariv@enertec.co.il
(2,169 Views)
Hi yarriv,
To get the sequence file use RunState.SequenceFilePath. This returns the full pathname.
To get the step name use
TS_PropertyGetProperty(propObj, &errorInfo , TS_PropertyName, CAVT_CSTRING, &Name);
If the propObj is for a Step Object then the step name is returned. If for a Sequence Object then the sequence Name is returned.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(2,169 Views)
