NI TestStand
Versions Listed
Group,
     I can go to MAX and select Software.  Below the selection is all my applications with their associated versions.  Is there a place, possibly the registry that lists the application and version that I can copy and paste into a text editor?
Tony
(3,061 Views)
Hi Tony,
All of the National Instruments Software information can be found in the Registry Editor. From there, you can copy the information and paste it into a text document. Launch the Registry Editor by browsing to Start >> Run and typing regedit in the window and then hit enter.  Then once you are inside the Registry editor, browse HKEY_LOCAL_MACHINE >> SOFTWARE >> National Instruments.  Browse through the folders and double-click on a key. Then copy and paste that text in a text editor.
Hope this helps!
Best Regards,
Jonathan N.
(3,051 Views)
