VI setup as modal dialog, is showing, but is not the active window in TestStand 2019
The first call to open a VI front panel from TESTSTAND shows the panel on top (it is setup as a modal dialog), but it is not the active window, forcing the user to left click on the VI before using the keyboard shortcuts that have been set up. All subsequent calls to VI's work as expected, i.e. they are both on top and the active window. What simple thing am I forgetting to do?
(1,052 Views)
Did you use the TestStand APIs to let TS know that the VI is modal?
Santhosh
Soliton Technologies
Only two ways to appreciate someone who spent their free time to reply/answer your question - give them Kudos or mark their reply as the answer/solution
(1,031 Views)
