NI TestStand
VI cannot executable. Error code -18002
hi all,
Currently, i have 2 same tester. ( tester A & tester B).-- Test stand 4.2 and Labview 2009 (Labview FPGA module)
Tester B corrupted, i reinstall labview but using Labview 2009 service pack 1 and Labview FPGA module SP1.
Found that  unconsistency test result in tester B.
i copy the VIs from tester A and run it.
Error message come out : The VIs is not executable. Most likely the VIs is broken or one of its subVIs cannot be loalocated. Select File>>open to open teh VI and then verify that you are able to run it. Note: Although this step is not in the main sequence, it is in the same file, and its module load option is set to " preload when execution begin". To avoid this error in the future, change the step or sequence file module load option to " load dynamically".
Then i run back original VIs ( tester B), same message pop out.
Any idea for that?
lian
(3,383 Views)
You need to open those VIs in LabVIEW and find out why they're broken. They might just need to recompile or there could be other issues with dependencies.
(3,377 Views)
hi Asbo,
Thanks for you response.
The Error message already solved what i done is rename and resave it. But another error message come again
" NI-RIO: (Hex 0xFFFF0925) The handle for device communication is invalid or has been closed. Restart the application. Error Code : -63195: User-defined error code.
Any idea for that?
(3,344 Views)
