09-17-2021 04:50 AM
Hello ,
I want to use the teststand api to place a customdatatype variable in the parameters of a teststand sequence and change its value. I am using LabVIEW to manipulate the teststand api. I know how to add standard variable in the parameters (String, number,...) with code bellow but not Setting custom data type .
Please help me,
09-22-2021 05:53 AM
Hi taoufiksmires,
This will create a container Parameter and add a couple of fields to it, is this the sort of thing you are looking for?
09-22-2021 06:15 AM
Think this will allow you to create your parameter from a Type.
Regards
Steve
09-22-2021 06:29 AM
Thank you Im gonna try it
