Using XNET database in teststand with selectable signal list
I have problems using the XNET database in teststand. I want a drop down menu of all frames(or signals) of a XNET database in teststand. Is this possible? I tried a VI that has a frame list and a signal list as input. When I click in the inputs using Labview, I can select my database and then the frame or signal. I saved the Labview-project and reloaded the VI in teststand. With teststand, the frame and signal lists are empty. The connection to the XNET database might be lost. I tried the Open Database function in Teststand but this does not load the XNET databases (udl file needed).
What can I do?
Greets
ManuKlause
LabVIEW 2018
Veristand 2018
Teststand 2017
(2,119 Views)
Hi ManuKlause,
I've got a product doing exactly this (step types collection + edit steps to read/write signals on a CAN bus based on a XNET DB).
You can contact me directly if you'd like to now more about it.
However the trick here is that we also had a hard time to make it work.
We ended up displaying rings which are populated thanks to XNET DB queries results...
CLA, CTA
View Cyril Gambini's profile on LinkedIn
(2,090 Views)
