NI TestStand
Using SequenceFilePreStep StepName to Run or Skip Step
Doug,
Thanks for the suggestion.
I'll try:
    theStep.SetRunModeEx("Skip", RunState.Execution)
and see if that works any different.  (it obviously should!)
  Won't be able to try it for a while because I have a test running.
  I did figure out a way to remove the Precondition "False" using the next step's SequenceFilePostStep, but it's not as clean as I'd like.
Mike
Message 11 of 13
(1,681 Views)
No problem. Note that if you are running the sequence in more than one thread or execution at a time (e.g. with batch or parallel model), there is a race condition with one thread changing the precondition out from underneath the other. These are shared settings. If you are only running one thread though then it doesn't matter.
-Doug
Message 12 of 13
(1,671 Views)
Doug,
By the way, I did get a chance to change to code to skip the next step using:
Runstate.Caller.NextStep.SetRunModeEx("Skip", RunState.Execution)
  and it worked great.  Changing the Precondition gave me other problems, such as if I had a precondition, I had to make sure that when I modified it, I had to make sure that it was back at it's previous state (not always easy).
The SetRunModeEx("Skip",RunState.Execution) works great, thanks!
Mike
Message 13 of 13
(1,640 Views)
