04-25-2011 02:59 PM
I need to use labview classes in Teststand 2010. I am not able to pass reference between Labview and Teststand.
11-22-2011 11:00 AM
Hi
TestStand does not provide native support to handle LVOOP objects directly. If you need to pass LVOOP object references through TestStand, National Instruments recommends the following procedure.
Using LabVIEW OOP Objects with TestStand
Houssam Eddine Kassri
NI Germany
11-22-2011 12:02 PM
TestStand 2010 added support for LabVIEW classes (more detail is in the TestStand 2010 New features help topic, LabVIEW support section), so this should be possible. Can you provide a bit more detail/screenshots on what you are seeing when you load a VI with a LabVIEW class? Are you seeing the same behavior with all LabVIEW classes or just a particular one?
11-22-2011 12:04 PM
Or leave it in Labview and use an action engine.
That's what I have done.
