08-11-2008 12:30 PM
Solved! Go to Solution.
08-15-2008 04:10 PM
Hello Vladimir,
Thank you for posting on the NI Discussion Forums. This was reported to R&D (#123249) for further investigation. The only workaround I can offer for now is to work with the VIs from version 8.5 of LabVIEW if they have vision controls linked to the connector pane. Thanks for the feedback!
08-28-2008 12:48 PM
This issue is related to the one described in this forum post: http://forums.ni.com/ni/board/message?board.id=330&message.id=21046
When a solution is found, it will be posted there.
09-18-2008 10:43 AM
