NI TestStand
Using ExtraPutty for Telnet Communication in TestStand
Hi All,
I am trying use telnet to communicate with a device using Teststand 2010 and I am not getting any response back read the results and displaying it in Teststand. Any help would be greatly appreciated. All my setup are correct and compare them with instructions given by NI.
WJ
(2,145 Views)
Hello justin1269,
I know that you mentioned that all the configuration is done as expected, but can you please share with us the steps you follow?
(2,119 Views)
Hi JKarma,
Thanks for the reply. See the picture below for my setting
WJ
(2,114 Views)
If you run this step, what returns? Can you just ping the device directly to see if you are able to communicate with it in general?
(2,109 Views)
I am able to get a response from the device via Telnet window, but not displaying anything returning into TestStand.
Willer
(2,076 Views)
