NI TestStand
Using ASAM XIL steps to call RT sequences on different targets
I am trying to use these ASAM XIL steps to call RT sequences,  my veristand simulation has multiple targets. How do I specify to which target the RT sequence will get deployed?
(1,556 Views)
Hello there,
I'm just wondering if you have found a solution for your problem?
I too have the same problem where I have 2 target and have no idea on how to select the deployed target
(389 Views)
Hello to anyone whose looking for a solution to this problem,
I have contacted a NI engineer regarding this issue and he has responded that there is no direct solution or a way to select the specific target from the ASAM XIL step. The current solution is to modify or copy the rtsequence and veristand project in order to apply it to a different target. Basically creating a separate file for the target. I hope this post will help with your projects. .
Lisa
(319 Views)
