NI TestStand
Use a Barcode-Rreader for communicating with TestStand?
Hello everyone, At my project 4 testsockets are executing in parallel and asychronously. Very often during the testing procedure the user is asked to input information to TestStand and this has to be done through a barcode reader. Most of the barcodes contain the information about which testsocket are referring to, but other times this has to be decided by taking into account the barcode previously read. I decided to use a Labview vi that takes inputs from the barcode reader, call it from the process model and let it execute in a different thread in the background. This vi should execute in parallel with the other 4 testsockets and every time a new barcode is read, the value should be passed to the right executing thread that would be waiting for it. I guess, this could be done by passing, everytime a barcode is read, the current barcode value to a station global and then send a notification to the right thread that should be waiting, to read this value. My question is, how is this done in TestStand? Thanks a lot!
(2,822 Views)
One of the ways to do it:
For labview vi which runs in parallel and reads the barcode :
In station globals have a  array where in stationglobals.slno[0]="socket_0_information",stationglobals.slno[1]="socket_1_information"....
The labview vi which runs in parallel can put the information in the respective socket station global variable.
For the tests sequence :
Override pre uut and remove the default behaviour of serial number popping.(skip/delete those steps).Add the following :
for loop
check stationglobals.slno[RunState.TestSockets.MyIndex] != "" // by default it will be empty else valid data will be present
Copy the value to a local variable
reset the station global value to empty for next iteration
time delay 1 second ( avoiding tight looping)
if(read value == "stop") \\ This is required for the final stopping of the tests
parameters.continue testing = False
end loop
(2,807 Views)
Thank you very much! This was really helpful!
(2,805 Views)
Hi
The Runstate.Root property can also be used to access socket information when using the batch or parallel models through the ModelData parameter.  The following example shows how to access whether the current socket is enabled:
RunState.Root.Parameters.ModelData.TestSockets[RunState.TestSockets.MyIndex].Disabled
Keep in mind that the available properties will change depending on the entry point used.
(2,796 Views)
