NI TestStand
Unload All Modules sometimes doesn't work with LabVIEW
TestStand's File >> Unload All Modules (and its RunState.Engine.UnloadAllModules() function) sometimes works and sometimes doesn't (with LabVIEW). When it doesn't, I have to quit LabVIEW to make TestStand unload LabVIEW VIs, otherwise I can't edit them.
Is there an "Unload All Modules" command that works all the time?
(5,247 Views)
Unloading the modules simply removes the access handle on the module. If the module is unlocked is decided by the runtime/development environment of the module.
Have you tried if Ctrl+m works on the "locked" modules after unloading all modules in TestStand?
Norbert
Norbert
Expert: Geometry
(5,246 Views)
I've also been using Ctrl-M over the past few months, and when the "Unload All Modules" doesn't work, neither does Ctrl-M. And vice versa.
(5,237 Views)
Is it possible that those modules are used somewhere else as well?
Do you possibly have a running sequence, aka "execution", in background (e.g. a callback sequence calling those modules)?
Norbert
Norbert
Expert: Geometry
(5,228 Views)
As far as I know, there are no modules, LabVIEW or TestStand, being used elsewhere. My TestStand main screen says "NI TestStand - Sequence Editor [Edit]", which usually means it's done and can release modules. But sometimes it won't let go and I have to restart LabVIEW to edit the VIs.
(5,219 Views)
Hm, i assume that you have callbacks defined which do call those modules. Possible callbacks to look first are: SequenceFileLoad/Unload, FrontEndCallback.
Another possible reason is that there are components running in the LV RTE (runtime engine) calling into the VIs you try to debug/modify in the development environment.
Can you pinpoint the "lock" to specific sequences/modules? Do they lock only after specific sequences/modules have been executed?
Norbert
Norbert
Expert: Geometry
(5,215 Views)
