Unable to load vi from TestStand
I have problem running test sequence in other pc but not in my local pc.
Problem PC:
TestStand version: 2012 f1 (5.0.0.262)
Sequence Editor version: 5.0.0.262
LabView version: 11.0.1f2
My PC:
The diff between this 2 PC is My PC has LV 2012 installed but Problem PC doesn’t have.
When I run the sequence, it gives error: “unable to load…..bla bla bla”
But when I open the LV file from the Problem PC, no broken arrow shows up.
Do you have any idea what goes wrong?
(3,910 Views)
What is the configuration of the LV adapter? Is it the same for both PCs?
Norbert
Norbert
Expert: Geometry
(3,906 Views)
Accepted by toyan
Thanks Norbert..
after set both PC with same adapter then i can run it. 🙂
(3,889 Views)
