01-29-2016 02:11 AM
Good Moorning to Everybody,
I've searched a lot but I don't find any answer to my my problem (I work in another workstation with teststand with my collegue), I've found only this reference http://forums.ni.com/t5/NI-TestStand/Proceed-with-next-UUT/td-p/2098196.
In my sequence I've needed to terminate the sequence,using the command RunState.Execution.Terminate(), but after this I don't want the gui as shown in figure:
I've already tried to insert the preUUT callback and postUUT callback in order to hide the banner blue request.
How can I procede??
Best Regards
Francesco
01-29-2016 02:35 AM
Francesco,
the reference you found provides all required information already.
If you do not modify the sequence status ("Terminated") to some other status, the Execution Entry Point of the process model generates this dialog (Handle Termination). So besides of changing the sequence status in PostUUT callback, the second option is to customize the process model by e.g. removing that step Handle Termination.
Norbert
01-29-2016 02:38 AM
Thanks Norbert,
How can I modify removing that step Handle Termination in process model?
Cheers
01-29-2016 02:45 AM
The recommended way is to create a copy of the process model (sequence file) in the user-directory of TestStand. Do NOT modify the original process model file!
Also you might consider to rename the process model (e.g. "Custom_SequentialModel.seq)
In the copy, you can either remove the step (Test UUTs entry point sequence) or modify the precondition as such that a "normal" termination does not evaluate to TRUE for the precondition.
Norbert
01-29-2016 03:18 AM
OK but this solution is not goog for me.
How can I approch ith the first your suggestion, so I mean how can I change sequence status ("Terminated") after the TerminateAll?
Best Regarda Francesco
01-29-2016 04:08 AM
Francesco,
you have to verify in the callback that the status is indeed "Terminated".
Use RunState.Caller.RunState.Sequence.Main["MainSequence Callback"].Result.Status == "Terminated" for this.
Then use the same lookup string to modify that status.
Note that the Test UUT entry point will skip the dialog step which results in a "continue to next UUT" behavior. If you want to quit execution properly, set "ContinueTesting" to false.
Norbert
