04-09-2014 02:43 AM
Is it possible to use DAQ NI USB-6008 directly in Test Stand (e.g. use a numeric test with an AD-Channel)?
Or is it required to use one of the supportet programming languages (LabVIEW, LabWindows™/CVI und Measurement Studio für Visual Studio .NET) , create a function/dll and call this from Test Stand?
Thank you.
04-09-2014 02:58 AM
You can leave out *any* programming language as the programming language itself requires an API (Application Programming Interface) from the driver to access the driver's functionality.
Most drivers are a single or a set of DLL(s), the API for the programming language is most often only a wrapper for that DLL(s).
Using the DLL adapter, you can access the driver directly as long as:
- It is a DLL which is documented about its functions and their parameters
- You know how to use the functions of the driver (specific order, which functions are required, which optional, ...)
Please note that you have to write a sequence calling quite a number of functions one after another. So a simple acquisition can consist of more than a bunch of steps if you do not encapsulate it into a single code module.
The recommended way to address your question is indeed: Use a programming language to call the driver.
Norbert
04-09-2014 03:16 AM
Thank you for your reply.
I understand that the driver contains function to initialize the DAQ, set outputs, read inputs etc.
I also understand that I could write a wrapper that calls a number of driver-functions to set up the card, and from TestStand I could call my own "init"-function.
The question is whether National delivers an API for the DAQ that allows to use the Inputs/Outputs EASILY in TestStand (e.g. one Action-Step to initialize the card, one Step to read a input, use a digital input directly for a pass/fail step, etc.)
Thank you.
04-09-2014 03:39 AM
There is nothing predefined. So you have to study the C-API of DAQmx yourself (documentation installed with the driver).
And, no, there are no examples which show this use case of DAQmx (direct driver call by TS)......
Norbert
09-13-2018 09:56 AM
Yes,
You can download NI-VISA and set up the daq channels in NI MAX. Using visa32.dll, you can initialize a resource and call up the functions you set up in NI Max. I know this answer is really late, but it can be used for future reference.
09-14-2018 12:28 AM
there is an other option by using a step-type
http://www.mesulog.fr/produits.php?art=3
Regrads
Juergen
