06-03-2021 03:42 PM
Hello, i need to comunicate whit this card USB-6525 and i dont know how. Can you explain me, how i can configurate usb-port in the NI 6525 for Teststand? or any solution?
06-10-2021 05:12 AM
Hi, There are multiple ways to communicate with USB 6525 device from Teststand. As you might know, TestStand is a Test management software so it can't communicate with your device directly. You will have to write test code modules/programs in one of the following programming environment and call those code modules/programs in TestStand to automate your tests.
NI does not recommend calling functions in hardware driver DLLs directly from TestStand. Instead, NI recommends that you create a code module from a supported application development environment (ADE) to interface with the driver and acquire data. You can then call this code module from a step in a TestStand sequence.
NI recommends this approach for the following reasons:
Refer to this link to get started - https://www.ni.com/pdf/manuals/373436f.pdf
