NI TestStand
USB-6003 DAQ module SW support
I am trying to incorporate the USB-6003 DAQ module into a test stand program. Is there a standard way to incorporate this or do i need to create a dll or another program so it can be called that way with DAqmx? Does a std dll already exist?
(2,253 Views)
You typically create code module (automation) in ADE ( like LabVIEW, .NET, Python etc.,) and call it as a TestStand step to sequence the operation.
What are you trying to achieve?
It may be possible to implement everything in TestStand but it will be tedious compared to an ADE
Santhosh
Soliton Technologies
(2,230 Views)
Thanks for replying. Yes I thought that was what needed to be done but I did not know if something generic was already written for this device so I could call it in with out developing the code to call.
(2,228 Views)
